Visa-motoren:
0,7 >> V06/644/655 >> 25 kW (35 pk) @ 5500 r/min
1,0 >> 108C-XV8 >> 32 kW (45 pk) @ 6000 r/min
1,1 >> 109/5 >> 36 kW (50 pk) @ 5500 r/min
1,1 >> 109/5 >> 42 kW (57 pk) @ 6250 r/min
1,1 >> 109/5F >> 37 kW (50 pk) @ 5500 r/min
1,1 >> 109K/5F >> 35 kW (48 pk) @ 5750 r/min
1,2 >> 129/5/5E >> 47 kW (64 pk) @ 6000 r/min
1,4 >> 150B-XY8 >> 58 kW (80 pk) @ 5800 r/min
1,4 >> 150D-XY7 >> 44 kW (60 pk) @ 5000 r/min
1,6 >> 180A = XU5J >> 76 kW (103 pk) @ 6250 r/min
1,7D >> 161A = XUD7 >> 44 kW (60 pk) @ 4600 r/min
1,8D >> 161/161A = XUD7 >> 44 kW (60 pk) @ 4600 r/min
Axel-motoren:
1,1 >> G11 >> 41 kW (56 pk) @ 6250 r/min
1,3 >> T13 >> 44 kW (60 pk) @ 5500 r/min
AX-motoren:
1,0 >> C1A/C3A >> 30 kW (41 pk) @ 5200 r/min ('86)
1,0 >> CDY = TU9M/Z >> 33 kW (45 pk) @ 6000 r/min ('92, U9!)
1,0 >> CDZ = TU9M/Z >> 37 kW (50 pk) @ 6000 r/min ('92, U9)
1,0 >> C1A = TU9 >> 33 kW (45 pk) @ 5200 r/min ('91)
1,1 >> H1A/B >> 40 kW (54 pk) @ 5800 ('86)
1,1 >> HAZ = TU1CP >> 40 kW (55 pk) @ 5800 r/min ('88, carb.)
1,1 >> HDZ = TU1M/L >> 44 kW (60 pk) @ 6200 r/min ('89, inj.)
1,1 >> H1A = TU1 >> 40 kW (54 pk) @ 5800 r/min ('91, carb.)
1,1 >> HDZ = TU1M/L >> 45 kW (61 pk) @ 6400 r/min ('91, inj.)
1,1 >> HDY = TU1MZ >> 40 kW (55 pk) @ 6200 r/min ('92, inj.)
1,1 >> HDZ = TU1MZ >> 44 kW (60 pk) @ 6200 r/min ('92, inj.)
1,3 >> M4A >> 76 kW (103 pk) @ 7200 r/min ('86, carb.)
1,3 >> M4A >> 70 kW (95 pk) @ 6800 r/min ('87, carb.)
1,3 >> M4A >> 69 kW (94 pk) @ 6800 r/min ('89, carb.)
1,4 >> K1A/B >> 44 kW (60 pk) @ 5400 r/min ('86-'88 )
1,4 >> K1F >> 49 kW (67 pk) @ 5400 r/min ('88-'91)
1,4 >> K1G >> 51 kW (70 pk) @ 5400 r/min ('88-'91)
1,4 >> K2A >> 62 kW (85 pk) @ 6400 r/min ('88-'90)
1,4 >> K2A >> 63 kW (86 pk) @ 6400 r/min ('91-'92)
1,4 >> K2B >> 62 kW (85 pk) @ 6800 r/min ('90-'91)
1,4 >> K2D >> 55 kW (75 pk) @ 5800 r/min ('91-'93)
1,4 >> KDZ = TU3MZ >> 55 kw (75 pk) @ 6200 r/min ('89-'90, U9)
1,4 >> KDY = TU3M/FM/L >> 55 kW (75 pk) @ 6200 r/min ('90-'92, U9)
1,4 >> KDX = TU3FMC/LZ >> 55 kW (75 pk) @ 5800 r/min ('92-'97, U9)
1,4 >> K6B >> 72 kW (100 pk) @ 6800 r/min ('91-'93, multipoint inj.)
1,4 >> KFY = TU3FJ2/Z >> 66 kW (90 pk) @ 6600 r/min ('91-'97, U9, multipoint inj.)
1,4 >> KFZ (TU3FJ2/L >> 70 kW (95 pk) @ 6600 r/min ('91-'97, U9, multipoint inj.)
1,4D >> K9A = TUD3 >> 38 kW (53 pk) @ 5000 r/min ('89-'94)
1,4D >> K9Y = TUD3Y >> 37 kW (50 pk) @ 5000 r/min ('93-'97)
1,5D >> VJY = TUD5/Y/L3 >> 40 kW (55 pk) @ 5000 r/min ('94-'97)
1,5D >> VJZ = TUD5/L/Y/L3 >> 42 kW (58 pk) @ 5000 r/min ('94-'97)
Zo... eindelijk dat lijstje eens in z'n compleet op 't net. Nu nog even wat andere TU-motortjes erbij:
Citroën C3:
1,1 >> HFX = TU1JP >> 44 kW (60 pk) @ 5500 r/min ('02-'04, U9)
1,4 >> KFV = TU3JP >> 54 kW (74 pk) @ 5400 r/min ('02-'04, U9)
1,6 16V >> NFU = TU5JP4 >> 80 kW (109 pk) @ 5800 r/min ('02-'04, U9)
Citroën Xsara:
1,4 >> KFX = TU3JP >> 55 kW (75 pk) @ 5500 r/min ('97-'00, U9)
1,4 >> KFX = TU3JP/L4 >> 55 kW (75 pk) @ 5500 r/min ('98-'00, U9)
1,4 >> KFX = TU3JP+ >> 55 kW (75 pk) @ 5500 r/min ('98-'00, U9)
1,6 >> NFZ = TU5JP >> 65 kW (90 pk) @ 5600 r/min ('97-'00, U9)
1,6 >> NFZ = TU5JP+ >> 66 kW (90 pk) @ 5800 r/min ('98-'00, U9)
1,6 16V >> NFU = TU5JP4 >> 81 kW (110 pk) @ 5800 r/min ('00-'04, U9)
Citroën Xsara Picasso:
1,6 >> NFV = TU5JP/L4 >> 70 kW (95 pk) @ 5700 r/min ('00-'04, U9)
1,6 >> NFZ = TU5JP+/L3 >> 66 kW (90 pk) @ 5500 r/min ('99-'00, U9)
Peugeot 106 Phase 1:
1,1 >> H1A = TU1/K >> 46 kW (63 pk) @ 5200 r/min ('91-'93)
1,3 >> MFZ = TU2J2L/Z >> 72 kW (100 pk) @ 7200 r/min ('94-'97, U9)
1,3 >> MFZ = TU2J2L/Z+ >> 79 kW (107 pk) @ 7600 r/min ('94-'94)
1,4 >> KDY = TU3M/Z >> 55 kW (75 pk) @ 6200 r/min ('91-'93, U9)
1,4 >> KDX = TU3M >> 55 kW (75 pk) @ 5800 r/min ('93-'96, U9)
1,4 >> KFZ = TU3FJ2 >> 69 kW (95 pk) @ 6800 r/min ('91-'96, U9, multipoint inj.)
1,4 >> K6B = TU3FJ2 >> 72 kW (100 pk) @ 6800 r/min ('91-'93, multipoint inj.)
1,4 >> K2D = TU3,2/K >> 55 kW (75 pk) @ 5800 r/min ('91-'93)
1,6 >> NFY = TU5J2 >> 74 kW (100 pk) @ 6200 r/min ('94-'96, U9)
1,6 >> NFW = TU5J2 >> 76 kW (103 pk) @ 6250 r/min ('94-'96, U9)
Peugeot 106 Phase 2:
1,4 >> KFX = TU3JP >> 55 kW (75 pk) @ 5500 r/min ('97-'03, U9)
1,4 >> KFW = TU3JP >> 55 kW (75 pk) @ 5400 r/min ('00-'03, U9)
1,4 >> KFX = TU3JP/IFL4 >> 55 kW 75 pk) @ 5500 r/min ('98-'03, U9)
1,6 >> NFW = TU5J2 >> 76 kW (103 pk) @ 6250 r/min ('97-'03, U9)
1,6 >> NFZ = TU5JP >> 66 kW (90 pk) @ 5600 r/min ('97-'01, U9)
1,6 16V >> NFX = TU5J4/L3 >> 87 kW (120 pk) @ 6600 r/min ('97-'03, U9)
1,6 16V >> NFX = TU5J4/L4 >> 87 kW (120 pk) @ 6600 r/min ('00-'01, U9)
1,6 16V >> NFX = TU5J4/IFL4 >> 94 kW (128 pk) @ 6800 r/min ('98-'99)
Peugeot 206/206 CC:
1,4 >> KFX = TU3JP >> 55 kW (75 pk) @ 5500 r/min ('98-'04, U9)
1,4 >> KFW = TU3JP >> 55 kW (75 pk) @ 5400 r/min ('00-'04, U9)
1,6 >> NFZ = TU5JP >> 65 kW (90 pk) @ 5600 r/min ('98-'02, U9)
1,6 >> NFW = TU5J2 >> 76 kW (103 pk) @ 6250 r/min ('98-'99, U9)
1,6 16V >> NFU = TU5J4 >> 80 kW (110 pk) @ 5800 r/min ('00-'04, U9)
Peugeot 306:
1,0 >> CDZ = TU9M/Z >> 37 kW (50 pk) @ 6000 r/min ('93-'94, U9)
1,1 >> HDZ = TU1M/Z >> 44 kW (60 pk) @ 6200 r/min ('93-'01, U9)
1,4 >> KFX = TU3JP/L3 >> 55 kW (75 pk) @ 5500 r/min ('96-'01, U9)
1,4 >> KDZ = TU3M/Z >> 55 kW (75 pk) @ 5800 r/min ('93-'97, U9)
1,4 >> KDX = TU3MCZ >> 55 kW (75 pk) @ 5800 r/min ('94-'97, U9)
1,6 >> NFZ = TU5JP/Z >> 65 kW (90 pk) @ 5600 r/min ('93-'97, U9)
1,6 >> NFT = TU5JP >> 72 kW (98 pk) @ 5700 r/min ('00-'01, U9)
1,6 >> NFZ = TU5JP/L3 >> 64 kW (87 pk) @ 5600 r/min ('97-'01, U9)
Peugeot 307:
1,4 >> KFW = TU3JP >> 55 kW (75 pk) @ 5500 r/min ('01-'05, U9)
1,6 16V >> NFU = TU5JP4 >> 80 kW (110 pk) @ 5500 r/min ('01-'05, U9)
Volgens mij was er hier en daar wel gewoon een schrijnend motortekort... Dit lijstje is trouwens wereldwijd, dus het kan zijn dat bijv. een 306 1.0 alleen in Afrika afgezet is. En dan kan je lang zoeken naar zo'n motortje... (als je het al wil)
- Ik had op een gegeven moment geen zin meer om de diesels ook nog toe te voegen, dus als je daar info over wil: Pb...
- Oh ja, ik heb van al deze motoren ook afstelgegevens enzovoorts... dus wat dat betreft: ook pb.
- Ik heb zelf bij een paar motoren de tekst "carb.", "inj." of "multipoint inj." toegevoegd, om het duidelijk te houden...
Voor meer informatie...
...is het internet natuurlijk een ideale bron. Er zijn diverse sites die informatie geven over allerlei modellen van Peugeot en Citroen. Hieronder zijn er een paar die ik er even uit wil lichten:
