Citroen Ax 1.1 By Patryk
Patryk
Re: Citroen AX 1.1 By Patryk
Post by Patryk »
Project AX Panda Style By Patrick finished
Citroën Ax król szos
Piekna Patryk!
Patryk
Post by Patryk »
hello friends, my AX 04/11/2014 celebrated 23 birthdays;) so was completely washed out;)
Image Image Image Image Image Image Image
https://www.youtube.com/watch?v=NXT6RHb ... sBMf_nwG7w" onclick="window.open(this.href);return false;
https://www.youtube.com/watch?v=iakon_S ... sBMf_nwG7w" onclick="window.open(this.href);return false;
Patryk
Post by Patryk »
AX still alive and enjoying my eye keeps older cars;) recently mentioned to him
The final silencer..all front suspension and clutch, and a few trinkets rest of the pictures;)
Greetings from Polish;)
Jeroenak
AX driver
AX driver
Post by Jeroenak »
Nice work Patryk! Good to have Citroën enthousiasts in Poland.
Patryk
Post by Patryk »
Hello all my ax 4.11 celebrated his 24th birthday and this year a lot has been mentioned;) all you have to picture Greetings from Polish
new threshold:
268984km ;)
WTBer
AX driver
AX driver
Post by WTBer »
very nice!
Patryk
Re: Citroen Ax 1.1 By Patryk
Post by Patryk »
Hello, my AX is still alive;) a little bit with him he made:
I replaced the spark plugs, ignition wires, air filter, a tube-inlet, rear left lamp and some other things that I do not remember greet AX enthusiasts
Patryk
Post by Patryk »
Hello, my AX rides all the time;) not long ago I replaced in it the starter and cable from the heater greet from Poland
Holländer
Post by Holländer »
You seem to take good care of the ax, nice to see. Keep up the good work! Isn't it snowing in Poland already?
looks good to have 277000km!
Patryk
Post by Patryk »
Hello, my AX is still alive and I made a lot of things with it .. I changed the thermostat, radiator and heater;)
PS: Can you write to me how to vent AX well because I have poor heating, once it does not heat once?
There might still be some air in the coolingsystem?
good reparations!
Patryk
Post by Patryk »
I have already vented it 5 times and each time heating works about 2 days after this time it appears and disappears, there is no sign of a damaged gasket under the head, for this I ask how to vent it well maybe someone has some helpful movie
