What size of wheels
marmottebeige
AX driver
AX driver
What size of wheels
Post by marmottebeige »
What size of wheels take for an AX GT? And what tires?
Thank you! :)
I like OZ wheels... :)
DLS
Post by DLS »
Normally its 14" but you can put 15" under it..
So wheel size should be R14 or R 15 then...
Mijn wie=wie
Citroën AX 1.4i TGS
Opel Astra G Caravan 2.0 DTL
marmottebeige
AX driver
AX driver
OK, THANK YOU :wink:
15 " wheels you need 195-45-R15, you have other tires, but i don't know the measures.
14" you can take 175-55-R14 or 185-55-R14 or things like that, with 14" you got more choice in tires.
but with 15" wheels you have more problems that the wheels can bump into your 'wheelhouse' (did i typ that right?) and that can damage your tires.
but first, i think you need to search for an Ax, and then look for the wheels :wink: :lol:
DLS
Post by DLS »
DuFF wrote:15 " wheels you need 195-45-R15, you have other tires, but i don't know the measures.
but first, i think you need to search for an AX, and then look for the wheels :wink: :lol:
I think its clear with that Wheelhouse
Anyway he ment the casing around the wheel to protect ur car from water etc. Maybe that way its more clear;)
haha
Mijn wie=wie
Citroën AX 1.4i TGS
haha
no i mean that when you drive over a bump, your wheel will bounce inside the wheelhouse, but when the wheels are too big, it will contact with the wheelhouse, and that will be the begin of damaged tires.
165/50R15 is possible too
DLS
Post by DLS »
haha
Lol that is what i ment to..;) that the tires will / can damage because they hit the protection of the car above the wheels:P
Mijn wie=wie
Citroën AX 1.4i TGS
marmottebeige
AX driver
AX driver
Are you sure for 175/55 R14...? it is not 175/60 R14 (79H) for to be OK with the technic control (DIV/apk)
I'm not sure... :?
for the indice "H" : is it an obligation??? : "T" is not OK too?
Thanks :wink:
TwoTone
Post by TwoTone »
The "T" and "H" are speedcode's
I'm not 100% sure about the maxspeed, but the "T" stands for max 190
km/h and the "H" for 210 km/h
"Waar een wil is, is een weg"
PeterM
Post by PeterM »
You are richt. standard is 165/65-14. Almost the same hight and often used are:
175/60-14
185/55-14
195/45-15
For as far i know the ax GT chic is nog formally rated over 190 km/h so a "T" tire would do fine at the DIV. Since the tires rated H, V , W are rated for higher top speeds you are always allowed to use them instead of a "T" tire. In generally a higher speed rating makes the tire more expensive and in a lot of cases you get less mileage from a high speed version.
When looking for bigger wheels in 3 bolt version you got little choice, that is why quite a lot of people convert the cars to 4 bolt versions.
P. :)
C4 vts
DS3
MX5 2.0
defender 110 3.5 kdfi
DS5, aan het aftellen
hasimera
AX Starter
AX Starter
Post by hasimera »
En ik maar denken dat ik op een nederlandse site zit te kijken.
:shock:
