Nu 28 euro in plaats van 36,28 euro.
Technische gegevens:
These beautifully chromed 'Pro Fuel' pressure regulators, can easily be adjusted to regulate the fuel pressure from your pump, prior to the fuel reaching your carburettors.
This will help to ensure the needle valve in your carbs float chamber aren't under too much strain and will reduce the liklihood of any dangerous fuel leaks.
Please choose the correct size to suit your fuel lines below.
Pressure regulation range down between 1>5psi, for non fuel injected cars.
These regulators have 1/8th NPT female ports.
Very easy to adjust
1 to 5 Psi adjustments
Beautifully chromed finish
Choice of fuel pipe fittings
Full fitting instructions included
