ax gti ABS
shmuliks87
ax gti ABS
Post by shmuliks87 »
hi .
i have a problem in the ABS
i replace my gear box to xsi 1400 , and the short axle( i think that this is the name of it)
anyway , the axle of the xsi doesnt have ABS and i drive in the car for 1 month in this setup.
in the first brack the ABS was run, and after the led was open and the ABS was off runnig.
i thought that this is becuse of the axle , and now after month i change the gear box for renew AX SPORT gear box,
and the original ABS axle.
i open the swith and for my suprised the ABS led still run in the mode of problem.
what can i do?? those the ABS computer have input or output to chack this thing??
can the sensor of the ABS is the problem??
also i didnt said that i need to drainage the air that still run in the brakes system, it have some effects on it??
thanks
shmuliks87
thats what I thought too..
what do you mean?
you swapped axes and now your ABS doesn't work??
you swapped the axes back and now it still doesn't work?
perhaps the problem is somewhere else..
edwin ss50
Post by edwin ss50 »
and a citroen ax doesn`t have abs
GTI 1.4 8v ---> GTI ... 16v
User avatar
Joris
Post by Joris »
edwin ss50 wrote:and a Citroën AX doesn`t have abs
wel ;)
shmuliks87
AX GTI!!!! There is Original abs
and yes i swapped the axes back and it still doesnt work/
i also clear the sensors from dust and other things
tried to replace the sensors and checked the wires??
shmuliks87 wrote:AX GTI!!!! There is Original abs
you are right about the ABS it was option delivered on the GTI
more I can't tell
