Hi,
Can anyone help me with how the electric window wiring works?
Passenger side is ok, drivers side will not go up or down, I have checked the motor, switch and fuses, they are all ok I don't know what else it could be.
Can anyone help?
Drivers Electric Window Problem
If you disconnect the cable from the motor, do you have power on one of the terminals of the plug if you use the switch?
If not, it could mean some kind of power supply problem to the window.
If you look at this thread:
http://www.axclub.net/forum_phpbb/viewtopic.php?t=6004
You will find some original schematics there, which might give an idea on how things are wired
